hi again wanting to take throttle body of to clean it,once i take it off do i need to replace any gaskets? i have teh crc throttle body cleaner just wanta make sure once i pull it off i dont have to run around looking for parts that i need to put it back on cheers
Ive had mine off and back on without a new gasket but I dident clean it or try to remove the old gasket.
I recomed that you replace the gasket they dont cost much at all and will stop problems further down the track if it starts sucking air through the gasket
Newer models use a metal gasket with silicone seal. Not sure if bolt pattern is the same on VE as VZ.
I remember taking the throttle body off to clean and used the same gasket but this time round I want to put a new one
