door acctuator
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by st3r3otyp3, Jun 27, 2008.
  1. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    Hi my missus front passenger side door is stuck I`ve read this is an acctuator problem so were do I find this in the door?, what does it look like? and is it hard to replace or am I better off leaving it to the pro`s.
  2. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    Same as VN im pretty sure?
    If so, **** easy to do, remove door trim, its a little black box, has two screws holding it to the door, undo them, remove the wiring, just clips apart, then manuver the rod off the end, you will see what i mean, but its **** easy to if its only the central locking actuator.
