Door card removal
Davison
Sideways
MY16
Trying to remove my front passenger door card, has anyone done this or have instructions?
duaned
Newcastle NSW
M6 Red Hot MSE
Yes I did it recently. It's not hard to do. Lets see how my memory is.
1/ Undo the 2 screws at the bottom of the door trim.
2/ Remove the rubber insert located inside the pull handle (electric window switches) and then remove the screw. Remove the switches by locating the square opening in the switch frame and pull upwards to release the switch trim.
3/ Remove the plastic cover located behind the door opener handle, then remove the screw.
4/ Remove the boot opener button and trim by pulling the trim upwards at the rear.
5/ Then remove the door trim. The clips at the top of the door trim sit horizontally so instead of lifting the door trim once the bottom has been pulled free, you simply pull toward you.
Installation is the reverse.
