door handle removal
kyl'svs
Holden Commodore VS Berlina
does any one know how to remove the inside door handle from the front doors?Ive got the door trims off.I think theres some sort of clips holding it but cant see how they work.
goldvnaero
HOLDENS RULE
Down South
VX SS A4
Hey mate,its relatively simple,there is a round circlip that holds the handles on,they are a bit of a pain to get out but you will be able to do it pretty easily,get a small flat head screw driver,and bend the tip of it,just a little bit,then push the door trim hard up against the door..without damaging anything,then have a close look between the handle and the trim and you should see two points on the clip..one on either end kinda thing..dont realy know how else to explain it,and push them,but be careful not to loose the clip because they do pop off with a bit of force are easy to lose..you will know wat i mean.takes a bit of practice but you will get the hang of it
