door trim help please
hoon1
hoon1
45
redlands
91 vp 5lt
how can i get the trim passed the air vent on drivers side the rubber want go passed it i cant work out how to get it in please help thanks hoon1
90VN55
34
stanthorpe, qld
90 VN SS 5speed, '90 VN Calais 5speed
have you got a pic cause i dont understand what you mean
hoon1
hoon1
45
redlands
91 vp 5lt
have a look were the door trim runs on the vn drivers side the top vent
90VN55
34
stanthorpe, qld
can u circle it in this pic?
or havent i got it in the pic
markovr
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
If its the door seal/trim bit you might have to take the vent side off by undoing the 2 screws on the side and the one from inside under the fuse cover door.Then take the 4 screws out that secure the vent itself from the dash edge.They are pretty recessed so you need a screwdriver with a bit longer shaft.When you have all the screws out it will be very loose if it shows some resistance keep looking for a screw that you have missed.
With that off the weatherstrip door seal should just come off.
hoon1
hoon1
45
redlands
91 vp 5lt
thanks markovr im trying to put one on ill give that a go thanks
