Door trim inserts
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Ron Burgundy, Oct 29, 2019.
  1. King Brown
    King Brown New Member
    Hunter Valley
    VF CalaisV Series2 6.2 Sportswagon
    Yeah. was always suspicious of "Not removable - welded instead" advice, as far more expensive procedure than 'insert tabs'.
  2. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    My SS came with that horrible looking glossy 'carbon fibre' trim pictured in images on the first page. It looks super fake.
    2015 and 2016 SSV came with nicer matte carbon fibre look trim (pic. Below).
    2017 redline had piano gloss black trim...
  3. Derekthetree
    Derekthetree Member
    Gen-F R8 SV Manual
    That is much nicer. My 2014 R8 has the same glossy grey "CFRP" as yours. Its not nice, but got used to it now, the suedette distracts from it a bit!
    Good luck in your trim adventures.
  4. mpower
    mpower Well-Known Member
    I have the matt look, it's pretty nice (MY15 Redline).
    The glossy does look pretty nasty in your pics, is it everywhere (dash, shifter, steering wheel, doors as well??).
    Gonna say that getting a set may be a case of coming across a wreck.
  5. Ron Burgundy
    NSW
    VF II SS
    In my car (2016 SS black edition) it is on the dash, shifter and front door trim. The rest of the trim is piano black
  6. KING46Calais V
    KING46Calais V Active Member
    2017 VFII Calais V 6.2L Sed
    Hi Ron
    Yes they are all removable.
    I changed my fake carbon fibre calais ones to the black woodgrain from a cream interior series one calais.
    Easy job, but the door trims need to be removed. They all just unscrew. Nil plastic weld.
    I posted before and after pics on here somewhere
    Ill see if I can find the post
    I even changed the gearshift surround and 3 dash pieces. They are all available separately from Holden without purchasing the door trims. From memory the whole set is around $600 for the 6 pieces
    Ron Burgundy likes this.
  7. KING46Calais V
  8. Ron Burgundy
    NSW
    VF II SS
    That looks excellent !
  9. Ron Burgundy
    NSW
    VF II SS
    So the door trim pieces can be purchased separately to the whole door trim ?
  10. Ron Burgundy
    NSW
    VF II SS
    I just bought these (ebay).
    Shifter trim piece is for manual so i will have to buy one for auto...
  11. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    link?
  12. Ron Burgundy
    NSW
    VF II SS
    Does anyone have a part number for shifter trim piece for auto in this matte carbon fibre finish ?
    Part no. For manual is 92263843
  13. KING46Calais V
    Thanks mate.
    Couldn't wait to get rid of the original ones.
  14. KING46Calais V
    Yep they can.
    Each piece is separate. No need to buy the whole door trim
    When I got quoted, I had to supply the VIN
    Just found a cream interior calais on carsales and used their VIN. Holden them gave me the part number for each piece. You could do the same if your having a hassle getting part numbers.
    Ended up finding them at a wrecker as the new ones were a bit expensive.
    And yes the door trims need to come off which is easy. Just take your time removing them and putting them back on so you don't give the retaining clips a hard time.
    Oh and I remember I had to peel back the soundproofing on the door trim to get to the screws then a good quality contact adhesive or hot glue to stick it back on. Don't have to rip the whole thing off, Just enough to get behind to the screws.
  15. Ron Burgundy
    NSW
    VF II SS
    Thanks mate !
  16. Ron Burgundy
    NSW
    VF II SS
    I was hoping that someone with matte carbon fibre insert could look up the part number which is underneath.
    Good chance to clean all the dirt around the shifter during the process ;)
  17. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
    Maybe this part 92263838
    Your current one might be 92263842
  18. Ron Burgundy
    NSW
    VF II SS
  19. abuch47
    Madelaide
    LSS3 YOOTE
  20. Ron Burgundy
    NSW
    VF II SS
