Doors broken
gleno5
97 vt commodore wagon
i have a 97 vt commodore wagon, the problem is that the back right door leaver is not connecting inside and also the child lock is on the door so i cannot get the panel off to fix it. would a coat hanger solve the problem??? or any ideas???
also the front right door the handle leaver does not connect either i have tried to take the panel off but its not popping off any specific way i have to take the panel off after i remove all bolts??
need help asap
thanks
gungazza
64
west suburbs
executive vt 5.0lt VZ CREWMAN
if you are takeing the door trim off look for hidden screws there is a couple there
gleno5
yeah i got them all but it is still getting caught up the top along the window. should i just give it abiut for pressure
Overdose
33
Albury, NSW
VT 5.0L Exec
Brute force and ignorance! works everytime, sometimes.
gungazza
64
west suburbs
just give it a bit of tap with your hand under the trim and it should come of
gleno5
ahk well i will give it ago and see what the outcome is
Hot-Rod
SuPaFlY -LiV3 Surviv3 Di3
Oz
forums.justcommodores.com.au
VX Commodore Series 2
the door trim slides up and off the door seal. Once you have removed all the screws it should lift off.
gleno5
also any ideas with the back door or would the coat hanger be the best one??
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
theres a srew that holds the inner door handle and some also have screw under that again
fitz_vt
Pass Me A Wrench.....
Adelaide - South Side
VT Commodore SII Olympic Edition
yes you need to take the window winder off before you can take the door card off, if you have electric windows you need to take the switches out before you take remove the door cards
