Double Row Timing chain issues
Single peger
New Zealand
Turbocharged vg ute, sbc r31 skyline wagon, multip
I know this has been covered multiple times with the whole double row timing chains but i ran into clearance problems that I haven’t read on any of the other posts,
ive got a vn series 2 3.8 that im about to rebuild, im in the middle of disassembling it and wanted to fit the mace double row timing chain ive got to check for clearances as i know people have had some issues, from things ive seen people post they’ve had problems with the oil pump but my first clearance problem seems to be the bolt that holds on the cam gear
probably more issues after that but thats my first one I’m trying to work around, any ideas?
Immortality
Staff member
Sth Auck, NZ
Got a picture of the bolt?
Single peger
New Zealand
ive got a few engines ive had a look at and seem to be the same issue im kind of stumped at the moment, it wouldn’t surprise me if ive over looked something so wanted to ask the question
Single peger
New Zealand
*UPDATE
Didn’t relise the balance shaft needed to be removed so issue solved only thing im interested to know now what have people put inplace to fill the hole?
woteva
NEED 4 SPEED
Adelaide S.A.
Just remove the gear, leave shaft in place.
Immortality
Staff member
Sth Auck, NZ
A picture is worth a thousand words ;)
On the 3800 V6 (VN-VR) models the balance shaft can be removed as it's dead weight once a double row timing chain is fitted. On ecotec models you MUST block the oil feed hole for the rear balance shaft bearing before it can be removed and discarded.
No need to fill the hole.
