double throttle body
Adriianz
GTS
hi i currently have 1 70mm V8 throttle on my 1994 VR v6 acclaim, i was wandering if anyone had any information into converting into a double throttle kit, is it possible for a 1994 vr? and if so if you know where it can be purchased, and what the increase in power is.
much appreciated. thanks.
stocky
34
no increase in power. massive overkill unless you have mods to suit it. your 70mm throttle is already larger than the engine can handle due to the neck size.
Adriianz
GTS
hmmm can i increase the neck size? to make it more efficient?
although, after the throttle went on, i did get a noticable power increase
stocky
34
you dont really. you would get the same effect if you just pushed the pedal down a bit more with the standard throttle. a v6 doesnt suck enough air to need a bigger throttle
Adriianz
GTS
hmm well anything you can recomend that will give it abit more kick? lols :)
thanks for the help mate.
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
turbo will help
monaro327
VZ Skaife Senator & VY SS UTE
you will get an increase in throttle response though with a bigger butterfly.
Adriianz
GTS
stroke it, port n polish, high ratio roller rockers , all of thoes will give u more kick
hmm where can those things be done, and how much do they cost, im pretty nooby with the engine modifications.. been doing looks so far.. only a throttle kit, chip & 2.5" exhaust so far lols.
thanks for the input
p.s i heard that turbos on a v6 are really not worth it, although supercharging are quite good :)
