Dragging rear brakes..
starliner
56
ulladulla
2003 vy
2003 wagon. Drive side rear started dragging badly, Checked hoses,slides,bled system (but not the ABS) ..it has improved however now both rears are dragging slightly but still more on drivers side. Any clues gentlemen?
krusing
Melbourne, Bayside
Is it the actual Brake Calipers ?
or
The Hand Brake Shoes ?
If its the Calipers -
Remove the Calipers,
Clean the Piston and Socket,
Install caliper service Kits "carefully",
Bleed the Brakes,
Adjust your Handbrake shoes,
Job done.
PS: Caliper Kits are available and not to expensive,
Most of all, take your time so you don't damage the piston and piston boots.
