drive belt issue
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jerozz, Sep 20, 2011.
  1. jerozz
    jerozz New Member
    adelaide
    vt commodore
    i got a 97 vt and just had a new power steering pump put in as the old one was whining and on deathrow. upon replacement and putting the drive belt back on it is now loose. the pulley seems ok. can the drive belt stretch out?
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    How loose are we talking?
    These have an automatic tensioner on them.
  3. jerozz
    jerozz New Member
    adelaide
    vt commodore
    really loose. the automatic tension has sprung back to position and seems ok but the belt is loose as if it has been stretched
  4. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Did you use the same pulley on the pump or did the new pump come with a pulley, if the pulley is new is it the same size.
    Is it possible that the belt has not been put on in the correct sequence.
  5. jerozz
    jerozz New Member
    adelaide
    vt commodore
    its the same pulley just a new pump. and the sequence i looked up and looks correct it has me stumped
  6. kizza50
    kizza50 Member
    VX acclaim S2
    It will be the way u put the belt on, next to the crank it will go around an idler everyone misses that
  7. jerozz
    jerozz New Member
    adelaide
    vt commodore
    and that i did i checked again and due to poor lighting i did miss that. gold star to you good sir thank you and thank you to all who helped
