Driver side water leak from air vent.
Does any one have any idea where it is coming from?
  • Thanks
    Votes: 1 50.0%
  • Much appreciated
    Votes: 1 50.0%
  • Total voters
Tutto73
50
NSW
2014 VF Storm SS Ute
Water is coming out of small air vent on driver side windscreen pillar when driving in the rain.
Ron Burgundy
NSW
VF II SS
It's coming from outside
stooge
wa
Turbo Alpaca
a general rule with water is always look above where you find the leak because water normally always flows down.
the little duct for the ac in the a pillar comes up from below the dash which would make water coming out of it very hard so i would look above it.
do you know if the window has been replaced because sometimes they do not get the seal right and it will leak.
pull the a pillar plastic trim off and soak the outside area where it is leaking and see if you can spot any water inside.
Fu Manchu
WA.
Do you have a sunroof?
