drivers power window and mirror
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
okay my mirrors will go side to side.... not up or down?
replaced power window fuse/relay, drivers side window wont go down i can hear a click behind the fuse box under the dash. if i hold the button down for more then 10seconds i can hear it click more then once atleast 3 times.
any suggestions for a fix ???
Fletch_QLD
Brisbane Bayside
VU II SS
Switch or mirror itself?
Happy
VYII Executive S2 3.8 Ecotec
My VT had the same mirror problem.
It was caused by dirty electrical contacts & I fixed it permanently.
Sorry to say I can't remember if it was the 4 way switch in the door inner trim panel or the contacts in the mirror itself but I was able to disassemble the offending item.
I think the window is a separate problem. Sounds like the relay is operating OK. (clicking sound)
Perhaps dirty output contacts within that relay. Try switching that relay over with another similar relay.
Also check that you've inserted your fuse/relay fully.
It all costs you nothing.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
If it's happening to both mirrors....I'd say switch.
Pull out the switch and clean with contact cleaner or replace.
If it's only the driver's side window that's faulty, it wont be the fuse or relay, as they control the whole system.
I'd say the problem lies some where in the driver's side window assembly.
May be faulty motor, dirty contacts, seized widow glass on the guides, seized regulator etc.
Also check the loom that goes from the body to inside the door.
They have a reputation of braking and fraying wires, with the constant opening and closing of the doors.
