i know i'm a few months behind the times on this post, but i'm looking at putting DRL in my VE (getting the time to do it all and the money to buy the parts is the issue atm), what my plan is with it, run the + from DRL through a NC relay (which will be wired to switched 12V source), tap that into the parker light circuit which when voltage is applied to the parkers, it will activate the relay, opening the circuit and cutting power from the DRL. i did that setup for a friend with a VE with no issue. has been working for him in excess of 12 months. will write up an instructable with wiring diagram when i have the time to do so
. doing it this way eliminates the need for a dimmer relay and is quite simple to do, the hardest part is finding good areas to run wiring and mount relays. for those interested i've come across a set of DRL with the 3rd wire (white) which hooks into the indicator circuit and flashes orange when activated (at the same time extinguishing that side white DRL for the duration of indicating). anyone interested feel free to pm me
