Hi alexandervf - If you get it fixed are you able to let us know how? As I had the exact problem, mine were flickering when installed as per the diagram.
So far it only seems to work for one or two people so keen to know where we went wrong in the process.
DRL:
So I went to a different auto-elect and they couldn't fix the flickering, so he yanked out one of the white wires so it stops the flickering but the DRL's run at full capacity with low beam on which is illegal in vic..
(I'm currently running the DRL conversion while having the DRL's on at high capacity at night)
HIDs & Standard Globes:
Now.. I bought H7 HID 5000k they worked for a only 20sec before cutting out completing, apparently in the VF has to high of voltage to support the HIDs or something on those lines (hard to explain), so the auto elect took them out. Now I've decided to go with standard globes which is what I should've done from the beginning but I didn't know.. So I purchased "Narva H7 12v 55w 4200K Maximum Intense Blue" - ADR APPROVED.
Seriously I've spent at least $500 over for all this and by the end of it I'll have Blue Low Beam lights and blue LED Parkers, Rego lights LED blue, Interior lights LED Blue and a DRL converter that runs at high capacity with low beam on.
Can @veessv please tell everyone how to fix the FLICKERING, two auto elects can't fix it so how did you!? Cheers guys
