Gus The Snail
Born to be dizlegzic
- Aug 29, 2007
- 528
- 21
- 18
- VS ute S2 1996
Drove my spare ute into the carport to have some panelwork done, and a new muffler fitted, All work done, but now it cranks for a few seconds, seems to fire on a random cylinder or 4, then stalls out. when you turn key off, and crank engne over again, it just cranks... occationally you get a pop thru the inlet, or out the exhaust, but still wont start. Its have injectors "cleaned" a day ago ( pulled out and ran compressed air backwards thru them onto a clean cloth and a few of them spluttered out some fine pieces of dirt ) and reinstalled, seemed to try to start ( read run for 3 seconds instead of 2 ) a little easier, but goes back to the whole cranks and cranks but wont start routine. Im changing fuel filter tomorrow afternoon, and will blow out the fuel lines from the connectors on the firewall ( remove fuel cap as to not blow a hose somewhere ), failing this not making it start and run as to keep running... what else could i look at? Its had new coils, leads and DFI module fitted from my ute, which was running excellently till i swapped out with a 304.
