DTC's
Discussion in 'VY Holden Commodore (2002 - 2004)' started by HSV 671, Jan 24, 2013.
  1. HSV 671
    HSV 671 New Member
    qld
    04 VY CLUBSPORT MM6
    Hi all.
    just got my Clubby back from the garage,
    Went in to read and clear Trouble codes held within the ECU. Came back with a
    PO122 TPS SENDER 1 CIRCUIT LOW VOLTAGE, CLEARED NOT RETURNED.
    P1122 TPS INTERMITTENT LOW-VOLTAGE-CLEARED- NOT RETURNED
    68 FAULT CODE (ABS) CLEARED- NOT RETURNED
    64 TPS (ABS) CLEARED- NOT RETURNED
    Found a Snap-On DTC on the web, Doesn't cover much on VY "V8" thou. Copy and Paste. Its in PDF.
    http://media.wix.com/ugd/b29b3a_c36090d90edcc358ec471801875c675a.pdf
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Roses Are Red
    Violets Are Blue
    I Dont Know What Is Going On Here
    Do You?
  3. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Id say they disconnected the throttle body at some point and the ABS module disable stability/traction control because of it.
    Did they sell you a throttle body clean?
  4. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    sorry for the hijack but how do you pull the DTC on a vy? i just bought my first vy today and am curious for future refference. and before someone says search, tried that.
  5. RiCeY
    Australia
    Scan tool?
  6. aussie4life11
    Western Australia
    Is that the only way? ive come outa a VR where all you had to do is bridge the ALDL under the steering column. can i buy a cheap scantool/Usb cable and use something like tunepro rt? if so where from. thanks.
  7. RiCeY
    Australia
    You can get them cheap, just be careful as not all scan tools do all Commodores. I got one for my VZ and it works on VZ and VE but not earlier Commos.
  8. aussie4life11
    Western Australia
    do you know of a site i can get one from for a vy series 1 exec? usb or scantool.
  9. RiCeY
    Australia
    Ebay is generally cheapest from my experience.
  10. aussie4life11
    Western Australia
    sweet as. gotta tell ya goin from VR to VY is awesome.
  11. RiCeY
    Australia
    Yeah I drive a VS V6 auto during the week and a VZ V8 manual on weekends and there's quite a difference hahaha.
  12. HSV 671
    HSV 671 New Member
    qld
    04 VY CLUBSPORT MM6
    No. No throttle body clean. Just a standard extract and erase. Only had the car for 2 weeks. Now the TPS has seemed to settle down a lot, it has a more smoother idle, doesn't rev up to 3000rpm when ya start the bastard and has a bit more poke... which is nice for a change.
    If it shits itself again, it'll be replaced.
  13. HSV 671
    HSV 671 New Member
    qld
    04 VY CLUBSPORT MM6
    Yep, it played up again driving home 3 times in 5 mins, everytime I backed off the throttle
  14. RiCeY
    Australia
    Whats it doing? Holding the revs high? Throwing engine lights? Limp mode?
  15. HSV 671
    HSV 671 New Member
    qld
    04 VY CLUBSPORT MM6
    Happened 25-1-13
    Back off accelerator, Check Engine Light appears with chime, trac control automatically switches "off", pressing t/c button in doesn't work, clutch in, revs up and holds to around 1800-2000 RPM and can feel it idling really rough. Don't think its limp mode, i just think its the TPS.
    To clear, well this works as a temporary fix....
    Pull car over, turn off and remove key, open drivers door, close drivers door and restart vehicle. I may have to do this about 3 times till it settles down. Sometimes its instant. Happens every time i back off the accelerator, throws a light.
    Scan tool has been on car and TPS gave a Low Voltage.
  16. RiCeY
    Australia
    If the ecu loses communication with the TPS, or there are any issues with TPS data, it will default to about 30% throttle. Same with accelerator position sensors. Trac control/stability is disabled as the ECU loses the ability to control throttle.
    I think you're on the right track thinking the TPS is the issue.
