DmanVT
USAWME
- Jan 11, 2011
- 469
- 0
- 0
- Location
- Lexton, Victoria
- '99 VT sedan II
Just a little more information for you, put basically..
The lights dimming is due to voltage drop across your wires. Performing a big 3 wire upgrade with thicker wiring decreases the resistance of the wire, which decreases the power dissipated across your wiring as by ohms law voltage = current * resistance and Power= current * voltage.. or power = resistance * current^2. Thus, less resistance = less voltage drop = less power dissipated = more power for the rest of your system, including your dimming lights!
If this doesn't work as effectively as you would like, you'll need a battery that is capable of supplying more current!
Capacitors are merely a bandaid solution that resist the change in voltage of your system, not really recommended. Do it right, do it properly.
Thanks mate, i have heard mixed opinions so just thought no harm in asking Local audio shop said to go dual batteries one for all boot and other for main and cap for when the bass comes in to hold power.
But they just say that coz they want to make a sale haha
Thanks for the input, and with the big 3 does it need to be 0 gauge??? would this do?? ...
Battery Cable - Per Metre, 125 Amp, Black - Supercheap Auto Australia
or would welding flex stuff work??? like the stuff they use for earthing wires in arc welders?? or should i get 0 gauge??
cheers
