richrever
- Feb 18, 2017
- 121
- 18
- 18
- Age
- 57
- Location
- Perve Western Australia
- Vs S2 V6 5,Speed Ute
Hi i recently got myself Vs v6 ute with duel fuel. When i first got it it ran ok but would rev up to 1500 to 2000 rpm (on gas) and very slowly drop down to around 1000rpm on start up especially on a cold morning as it got warmer it got better but would randomly do it warm. Switch to petrol and it would still do it but not as bad but unfortunately as it warmed up worse it ran. First thought bad fuel.drained and replaced that. Nope. Fuel filter? Nope. Then found a vacum diafram thingie disconnected and pluged(after the diafram thingie).. plugged it before it and made a good difference but still not perfect or close but better. This diafram thingie im assuming must have something to do with the gas system but gas is new to me so i dont know what its for or where its spoused to go. Leave the gas side alone get the petrol side fixed. Codes codes codes.1st...12-19-58-65-76 tps stuck.transfluud temp.lh rich exhst.short term fuel trim..... All i did was clean up and check all connections. Kept driving it as it was a little better and ignored check light. Finally read the codes again(i wasnt driving far or fast generally)....19.22.23.32.44.65.76.85.tps stuck.tps.mat.maf.lean fuel. lh rich exhst.short term fuel trim.85 i cant find a code that high?. Replaced tps mat maf . Alas didnt make much differance. Checked for vacum leaks with start bastard. Research tells me the ecu gets hacked into or feed data for the gas and that must be what the lambda control unit thing i found stashed in the engine bay. Anyhow i dont kniw anything really about gas systems and learning i know less about the runnings of computer run cars than i thought. Oh and if it makes any difference and i think it did a bit yhe exhaust was buggered with holy muffler until last week. I hoped fixing that would fix every other thing. No just less noisey. Checked the codes again....22.23.32.44.76. Grrrr. Anyhelp would be appreciated
Cheers Rich
Cheers Rich
