Duel fuel vx cranking but not starting help!
Boof_94
Vt executive
Hi all, been hunting high and low on the thread to see what I can find in regards to a vx cranking but not firing but haven’t had much luck,
So the other day I brought a vx for dirt cheap now they said the car ran before they parked it up, its also on gas and fuel, it was missing 2 injectors I put 2 new injectors In it today, and a battery witch by rights should of started the car, i know it’s got spark, as I also tried to swap the coil pack as well, unsure how good the fuel is in it, put a scan tool on it didn’t throw any codes,
Iv tried to swap the start rely and the fuel pump rely with a working on, all fuses are good, any idea what it could possible be and how can you tell if it came out factory duel fuel?
Cheers in advance.
