Dumb roller rocker question
darky82
VX Berlina S1 5.7L
Do roller rockers just sit on the stud and hold up by the push rods and valve-spring or is there a spacer or a taper in the stud they sit on... call me dumb but ive never played with roller rockers before :hmmm:
immortality
Staff member
Sth Auck, NZ
stud mounted is old school and not really used on Holden unless you go to after market brands (but yes, your basic description is correct). the most common Yella Terra roller rockers are shaft mounted, in which the rocker pivot has a shaft through it which is bolted to the head on a pedestal which is much more solid and stable at high RPM
see Yella Terra - Part details
Pub247
Melbourne S.E.
Ford Fairmont
Your goning to need a few more than one :p
darky82
VX Berlina S1 5.7L
got a set man, is that all you need no spacer
ari666
250,000 hits
you will need guide plates to stop your pushrods going sideways.
personally i think those are better than shaft mounts cos they are a TONNE easier to get the adjustment right. bloody shaft mount always flick your allen key out of the hole. frikken annoying.
edit. oh right didnt see the guide plates. nah thats all you need.
immortality
Staff member
Sth Auck, NZ
you'll also need hardened push rods.
darky82
VX Berlina S1 5.7L
yeh i got the hardened push rods, yeh i went with hydrolic stuff so i dont have to do it every month....
