Dumb things you've done working on a car?
Discussion in 'The Pub' started by Scooter79, Nov 21, 2007.
  1. trent d
    trent d New Member
    rothwell qld
    vn executive
    Drove over the top of my car ramps the first time I used them
  2. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Sitting at home bored one day and thought I'll bolt I'm sub down, made some brackets and went out to car. Started drilling into the boot floor. Didn't finish the job only had the holes drilled. Later that night I jumped in car to go to the shop and there was I strong fuel odour in the car, popped the boot and the odour took the air. Stay out of me, smelt so strong. Anyway I drilled straight into the fuel tank
  3. jason_85
    jason_85 New Member
    Wodonga
    02 Vy SS and 99 Vt SS
    the stupid thing i did was, taking the intake manifold off my vs statesman to clean it all out... anyway it was getting a bit late so i thought id stop for the night and coz it was a shared carport i locked the car and closed the bonnet.... went back to it in the morning and the car wouldnt unlock (key didnt work in the door) and remembered that i disconnected the battery.... anyway after a couple hours trying to break in (never done it before), i decided to look around on here and seen that it could be unlocked with a spare battery and jumper leads running to the starter... probably an easier way but living in the middle of nowhere parts arent cheap...
  4. Jonah 101
    Jonah 101 Undefined
    Rotorua
    R32 Skyline
    Welding the roof up on my N12 Pulsar and lighting the roof liner on fire!
  5. turmoil117
    turmoil117 Donating Member
    Armadale
    Vs berlina
    Sometimes I jumo in my commodore (auto) straight from my magna (manual), I always crap myself when I slam down on the brake pedal thinking its the clutch
    Sent from my GT-I9100T using Tapatalk 2
  6. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    smashed my head on the exhaust the other day getting under the car AND on the way out while putting my new billet shifter in....
    Felt dumb... + walking around with a 2" red line across my forehead for the next day and a half didnt help :/
    ..shouldve waited til the exhaust cooled down.....
  7. Jonah 101
    Jonah 101 Undefined
    Rotorua
    R32 Skyline
    Have you ever hit your head on something then as you pull your head away for what you just hit ( like knee jerk reaction ) hit your head again!! This is a sure way to throw me into a fit of rage.
  8. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
  9. Unbreakable
    Unbreakable New Member
    Adelaide Hills
    1983 VH SL
    Snapped a water pump bolt on my old merc and got it stuck in the block boy was that a bitch to get out.
  10. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    yes....
    i lose my **** when that happens
  11. uniacidz
    Sideneee
    VE Berlina
    Simpsons - Sideshow bob steps on rakes - YouTube
    and yes, hit my head once, cursed and went to duck again and hit it again just as hard.
  12. skappascrap
    skappascrap Herp is for the derp.
    '02 VY SV8
    I was cleaning the plemum out of my VS V6 Ecotec at night (around this time last year), dropped a bolt down the first intake runner, couldn't reach it so I had wait a couple days to get an extension magnet arm.
    Newbie+ night time= bad time.
  13. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    I dropped a plenum bolt down a runner while cleaning my Ecotec. Had to walk about 5km to Autobarn to get a 'piss weak magnet on a flexi-handle' tool (probably not its real name), walk back, and spend 30 minutes to get it out. And just after I got it out, I dropped the next bolt down the same runner, motherfu****.
  14. Drawnnite
    2000 Vs Ute
    did it (if memory serves me right, because it was probably enough times for concussion) a good 5 times one day.
    working under this machine at work, and it was at the height you can just slide under it on your back (because you know. putting all the connections and areas for cables etc under in the worst spot is a great idea)
    its like biting your tongue. then doing it over and over again.
    also.
    pulling something apart. putting all the screws down. not all mixed up, with the actual piece it was taken out of
    then after you put it all back you somehow manage to find 1 screw still sitting there.
    it doesnt even make any sense! =P
  15. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    While fitting a Mace manifold insulator , I dropped 3 of the plenum bolts gown the chamber , no probs , got them out , when I thought the job was finished , went to start the car and the thing revved like Billy O and a smallish fire started , DOH , then I discovered that the back left injector was not seated correctly , so the car was towed down to the local Holden dealer and , so yeah , goes well now though . One of the mechanic's still brings that up occasionally . PR&*K
  16. stovepipe
    stovepipe New Member
    Australia
    VU SS
    Went to fit a new oil sensor in my vu ss last night. Dropped the New one in straight away. Didn't fall out the bottom and can't find It anywhere. Any tips???
  17. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    Always stuff rags down the runners after the first time you drop a bolt down there lol.
  18. ari666
    ha! this thread! cool!
    not sure if i posted it already, but i had a bunch of rags covering my valley to stop dust and **** getting on the lifters, anyway fully installed the intake, torqued to spec etc, then went "ummm, where are those rags... nek minit, intake is back off, sure enough, still in the valley.
    i remember someone a while back actually started their V6 with the rags inside. wasnt pretty.
  19. Pollushon
    Pollushon Boost gives me a bar....
    VY SS
    I feel special, my valley had a gut full of rags yesterday, all accounted for.
    Brake pad backwards, and forgot to tighten a power steering high pressure line once. Made it two intersections before it dumped all the fluid, mostly on the exhaust, smoke heaven. Was a Saab 9000 turbo.
  20. Rusty
    Rusty ٩(-̮̮̃•̃)۶
    Queensland
    Vt with VU/VZ bits
    When I was about 15 and doing some spraypainting - Filled up the big pressure pot ready to go. Hooked up airlines and turned on compressor. Forgot to screw the lid tight. Pressure pot lid went flying and I painted the entire room in about 2 seconds. Was one hell of a clean up.
    Another time somebody put thinners in the hardener tin. Painted majority of the car and then had to scrape the lot off with razors a day later
