AmmoJammo
- Aug 5, 2010
- 650
- 0
- 0
- Location
- Adelaide, Australia
- VL Wagon
sounds good, once you get the monoblock you can wire it in parallel.
stupid advice.
leave it as is with the coils in series, and the channels bridged.
it gives the sub the same power as if you wired 1 coil per channel, and means each channel is running at 4 ohm, which is perfectly fine, and well within the amps limits, meaning it should never overheat.
Expecting both voice coils to move at the same time when each being wired to a seperate channel is just ludicrous.
All then care to explain how you would wire a DVC 4 ohm to a 4 ch amp rather than just saying yes it's ok...
