dvd screen
smitroast
wynnum
vz sv6 commodore
i just installed a 7 inch into the dash frist only the back two speakers were working which i was fine with until just now only the right back speaker i have all 4 speakers running from and amp and when i was installing i couldnt find a vz wiring diagram can anyone help is it just that the rda? cord is night wired up to the right wire or do i need to wire all the stock vz speaker wires into the new lume can anyone help me :)
Hrd455
Vz v6 ute
The diagram is on top of the oringal blaupunkt stereo
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
if you are running amp for speakers yes you have to connect to amp outputs,
smitroast
wynnum
vz sv6 commodore
fhe amps are connected to the outputs and ill check the original headunit
