Torque is a force. Horsepower is a measurement of how much of that force can be applied over a given time.
FYI the fastest car isn't which one crosses the line first.
Mph is the best and most accurate way to work out a vehicles power, aside from an engine dyno. Mph never lies.
MPH? How is that the best?
Pressure, air temp, car areo, car weight, track conditions, driver and reaction time all influence MPH so how it that more accurate than a dyno?
With a dyno, you just need someone who knows what they are doing and a correctly calibrated dyno.
Bosch Blue Top 775 Injectors 24lb & Freshened Up Motor a Little.
Injectors are way to small.
Stock is 30 lb, supercharged 32lb, raptor supply 36lb with their supercharger kits (all from memory).
Can someone double check my numbers ?
Lol u can pick up 10rwkw on a dyno by simply tightening or loosening the straps. A dyno is simply a tuning tool.
A given car will run a certain mph for its weight and power. Moroso slide calculator.
From a vehicles mph you can work out what it should et in a "perfect world".
Et's are influenced by variables. That's why u can run a 12.3 @ 112mph and 13.3 @ 112mph
i dont fully agree with that either as cars with big turbo's can do a crap mph due to turbo lag but put out big hp..
