Dyno Sheets
Discussion in 'Dyno Figures' started by AirStrike, Apr 25, 2007.
  1. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Deuce / Mike / VR SS
    HP (222.5hp), kW (166.0rwkW) Over 500Nm @ rear wheels
    Engine Type and Capacity: LB9 5.0L Holden V8
    Power Adders: Coby Tri-Y Extractors (ceramic coated) & 2x 2.25" to 2.5" single exhaust, MACE CAI & 70mm TB, Crane Gold 1.65 Roller Rockers, C.O.M.E alloy Heads with 2.02" Intake Valves, near standard PCM chip
    Trans Type: M30/4L60E (Kitted & cooled)
    Diff Ratio: GU4/3.08
    Wheel/Tyre size: 225/55-16
    Fuel Type: BP Ultimate
    Name Of Workshop: TeRapa Automotive
    Date Dynoed: 31/07/12
    This Dyno Run was just for Comparison reasons (Car will be tested again once the stroker kit and cam are added)
  2. MattP
    MattP New Member
    South Australia
    VE SS
    VE SS - Pacemaker Extractors, 200cpsi, 2.5 KPM CB, VCM OTR
  3. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    WogBoyz/Adam /2008 VE SSV UTE
    HP 477RWHP/351rkw 721nm
    Engine Type and Capacity: 6L V8 L98
    Power Adders: KPM 3" zorst, 1 7/8 pacemaker coated headers, Oztrack HPS cam, Oztrack Heads, VCM mafless otr, Also have catchcan, cooler themostat, removed beauty/noise cover off manifold aswell
    Trans Type M6
    Diff Ratio: 3.7's
    Wheel/Tyre size: 20's
    Fuel Type: Shell V Power
    Name Of Workshop: Hunter Automotive
    Date Dynoed: 21/8/12
  4. dmacey
    dmacey Somebody, make me upset
    SSV Series II Sedan Manual & a VK in the build
    Nice work mate!!!!!
    gotta love that
  5. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    haha thanks man cant wait to see the dyno sheet when i get the blower! :D
  6. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    Kiddo/ Jon /2008 FG XR6
    HP 205RWHP/152 RWKW 628 NM
    Engine Type and Capacity: 4.0ltr
    Power Adders: Pacemaker 4500's, Herrod CAI, Tune
    Trans Type A5
    Diff Ratio: 2.73
    Wheel/Tyre size: 17"
    Fuel Type: Ultimate
    Name Of Workshop: Dynolink Townsville
    Date Dynoed: 16/8/12
    I still miss my old commodore :(
  7. 97VTSS
    97VTSS Guest
    HOLDEN COMMODORE 1997 195i VT SS
    Hi. I'm Geoff
    Engine
    195i 5 Litre V8
    Diff - Standard
    Wheels - 17x8
    Gearbox - M34 Getrag 5 speed manual.
    Dyno by - Chip Control, Sunbury, Vic.
    Date Dyno'd 8/1/12
    Fuel - Regular Unleaded. (As far as I know.)
    Custom aluminium port matched high flow intake manifold and mafless tuned OTR cold air intake. Custom twin 60mm throttle body. Heads ported, polished and shaved 10 thou. With Yella Terra roller rockers and heavy duty double valve springs. Crane 888241 camshaft.
    Custom PCM chip upgrade including maffless tune.
    Pacemaker extractors into a 2 ½ inch twin cat back exhaust system with high flow catalytic convertors.
    Polished aluminium valve covers. Billet clutch master cylinder and various polished aluminium and chrome components.
    Rev limiter @ 6200 rpm
    341 hp @ flywheel (255 kw)
    275 rwhp (203.7 kw)
  8. Jesterarts
    2010 Nissan X-Trail ST-L
    Jesterarts / Raf / 2005 HSV Z Clubsport R8
    HP (413.6hp), kW (308.4kW)
    Engine Type and Capacity: LS2 6.0L
    Power Adders: 23*/23* Cam, Higgins heads, OTR and tune
    Trans Type (M6, A4, etc): T56-M12
    Diff Ratio: 4.11
    Wheel/Tyre size: 235/40R18
    Fuel Type: BP98
    Name Of Workshop: Chevs Performance Centre
    Date Dynoed: 03/09/2012
  9. Kuz
    Kuz New Member
    VE SS-V Sportswagon Redline
    Kuz / Michael / 2011 (MY12) SSV Sportwagon Redline Ed.
    Power: 305rwkw 728nm
    Engine Type & Capacity: 6L V8 L77
    Power Adders: VCM OTR CAI, DiFilippo 2.5" Full Exhaust System with HPC Coated Headers, 224/230 Comp Cam, HD Valve Springs, DOD Delete Kit (LS7 Parts), MAFLESS Tune.
    Trans Type: M6 T6060
    Diff Ratio: 3.7
    Wheel/Tyre Size: 19x8" with 245/40R19
    Fuel Type: BP 98RON
    Name Of Workshop: Powertorque Engines
    Date Dynoed: 22/06/2012
  10. brocksta05
    brocksta05 Member
    somewhere NSW
    2000 VT S2 Acclaim
    brocksta05/ Brock Haron/ VT S2 Acclaim
    HP (XXX.Xhp), kW (100.3kW) (If you only know one, ill work it out for you)
    Engine Type and Capacity: 3.8 ecotec
    Power Adders: redback catback exhaust and K&N panel filter
    Trans Type (M6, A4, etc): A4
    Diff Ratio: 3.08:1
    Wheel/Tyre size: 16x8" 225/50/R16
    Fuel Type: United 95RON E10
    Name Of Workshop: SAMS Automotive
    Date Dynoed: 18/11/2011
    The car itself was running fine but its got alot of kms on it. And at the time we didnt know if the dyno was accurate as it was only set-up that day.
    The car will be going back on the dyno in January at Kandos Car show to see what it makes now with all the extra bells and whistles haha :spot on:
  11. Kiddo
    Mitsubishi Colt
    HP 224RWHP/166 RWKW
    Trans Type A5
    Diff Ratio: 2.73
    Fuel Type: Ultimate
    Date Dynoed:22 /9/12
    Had my tune cleaned up :)
  12. ari666
  13. Jesterarts
    Ari. look at the torque scale. ;)
    @ 5252rpm torque = hp. Doesn't mean the graph will always intersect there because, in the case of my graph, the scales are different.
  14. ari666
    i know we clarified in chatbox, but for those too tight to donate:
    there is ONLY torque. horsepower does not exist, its a fictional calculation based on torque and RPM.
    HP=TQ x 5252 / RPM
    soooo, ALL calculations will ALWAYS intersect at 5252 RPM (metric calculations are different) if you get 500ft/lbs at 5252 or 300ft/lbs at 5252 HP will always intersect at that point, itll just be higher up the scale or lower.
    if the 2 intersections happen at differing RPM's (in that dyno sheets case, 4250RPM and 5000ishRPM) then there is some mystery calculations going on and the sheet needs to go in the bin.
  15. Jesterarts
    Agree. Torque = Power @5252.
    But, dyno print outs will no necessarily show the torque curve cutting the power curve unless they are plotted using the same scale. Is the scales are independent, as is the case with my print out, they won't intersect at that point. The one weird thing with my chart is before and after. Because assuming both are on the same scale, both should intersect at the same rpm.
    Cheers.
  16. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    Cpbait / Ben / VY SS
    HP (431.9hp), kW (322.1kW)
    Engine Type and Capacity: LS1 383 stroker.
    Power Adders: Pacemaker 1-7/8" headers, sureflow cats and twin 2.5" into single 3.5" exhaust. 25% underdrive pulley, comp cam, head porting, plus some other exrtas.
    Trans Type (M6, A4, etc): A4, 3,600 stall.
    Diff Ratio: factory 3.07 (for now).
    Wheel/Tyre size: 235/40R18.
    Fuel Type: Bp98.
    Name Of Workshop: Chev's performance.
    Date Dynoed: 22/10/2012.
    Dyno sheet to come asap.
  17. cpbait
    cpbait New Member
    Dyno sheet from my car. Sorry about the poor pic, was uploaded from phone.
  18. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    Thats pretty good power Ben, time for the blacktop I say
  19. CAPRILICIOUS WL
    CAPRILICIOUS WL New Member
    WL CAPRICE
    CAPRILICIOUS WL / Dave / 05 WL caprice 190
    HP (XXX.Xhp), kW (139.7kW)
    Engine Type and Capacity: Alloytec 190 3.6L
    Power Adders:
    CPR6
    SS CAI
    Twin 21/2 xforce exhaust
    Hi flow cats
    20% underdrive pully kit.
    XXXXX
    Diff Ratio:
    3.9 LSD
    Wheel/Tyre size: 245/35/20
    Fuel Type: BP ultimate 98oct
    Name Of Workshop: XXXXX
    Date Dynoed: Oct 2012
  20. cpbait
    cpbait New Member
    Yeh very happy with it, just got to run the engine in some more on the street and better tyres, then give it a run on the black top and see what it pulls, then a diff gear change and see from there.
    So should be running it soon and see what it pulls.
