Dyno Sheets
captaincruncher
Bendigo
VR Commodore
Your forum name Julian / Holden Vr V6
HP (153), kW () (If you only know one, ill work it out for you)
Engine Type and Capacity:Buick 3.8 V6
Power Adders: V8 throttle Body, CAI, Hi-Tech Headers, 2.5 Exhaust, Removed Restrictor
Trans Type (M6, A4, etc): 4L60E
Diff Ratio: 4:11
Wheel/Tyre size: Stock 15's
Fuel Type: 95 Premium
Name Of Workshop: Jason Clark Automotive
Date Dynoed: 26/11/2010
RUF-60L
Donating Member
2008 VE SS
SYC05S / John / 2007 VE SS
HP: 353.36hp
kW: 263.5kw
Engine Type and Capacity: Gen IV 6L
Power Adders: Stainless Steel Dual 3" Sureflo Exhaust, Pacemaker 4 into 1 headers, Ballistic Cats, Duspeed OTRCAI
Trans Type : A6
Diff Ratio: standard (not sure exactly what it is)
Wheel/Tyre size: 20 inch wheels, 245/35 tyres
Fuel Type: 95 Unleaded as far as I can remember
Name Of Workshop: Tune done by Oztrack, at Race Solutions workshop
Date Dynoed: 08/10/2010
|<untzie
Pontiac Grand Prix Turbo
thought id share from canada
|< untzie/ Jeff/ PONTIAC Grand prix
HP 583 fwhp 551wtq
Engine Type and Capacity: 3.8 "ecotec equivilent"
Power Adders: turbo
Trans Type M5
Diff Ratio: Front wheel drive
Wheel/Tyre size: 285/35/18 18x8.5
Fuel Type: 94 with alky injection
Name Of Workshop: homemade / cartuning
Date Dynoed: august 17/2010
lowxr
1964 thunderbird
low_xr / dylan/ ve maloo r8
HP (456.2hp), kW (340.2kW)
Engine Type and Capacity: 6lt LS2
Power Adders: cam, intake, tune, x force headers-cats- 3'' catback, k+n filter, single piece pushrods etc etc
Trans Type (M6, A4, etc): M6
Diff Ratio: 3.70
Wheel/Tyre size: 275/35/19
Fuel Type: mobil 8000
Name Of Workshop: c+A auto fasions
Date Dynoed: 27.8.2010
STEEV888
33
central coast
'95 200sx.
STEEV888 / STEEV / 03 YII R8
HP (300.0hp), kW (225??kW) (If you only know one, ill work it out for you)
Engine Type and Capacity: 5.7L LS1. BOG STOCK + 120,000KMS
Power Adders: NOTHING.
Trans Type (M6, A4, etc): T56
Diff Ratio: STOCK (THINK ITS 3.08?)
Wheel/Tyre size: 245 35 19
Fuel Type: PREMIUM.
Name Of Workshop: SUMMERNATS 24. DAT PERFORMANCE
Date Dynoed: 7/1/2011
IT DID GET HIGHER BUT THIS ONE WAS THE COOLEST (HIGHEST WAS 307HP)
RazzaCaine
Long Gone Now
Your forum name: Ryan / Holden VB 308 (VK)
HP (210), kW (153)
Engine Type and Capacity: Black 308 5L V8
Power Adders: single 2.5" exhaust system, mild cam (unknown specs), roller rockers (again unknown specs), electronic ignition
Trans Type: M20 4 speed manual
Diff Ratio: 3.08:1
Wheel/Tyre size: 16s
Fuel Type: 98 Premium
Name Of Workshop: Specialty Tuning Marion
Date Dynoed: 14/01/2011
VT-565
QLD
VT
Your forum name: VT
309.4rwhp, 230rwkw
Engine Type and Capacity: 4 litre V6
Power Adders: M90 Supercharger @ 9psi, ECU, Intake, Exhaust
Trans Type: 5 speed Auto
Diff Ratio: 3.53:1
Wheel/Tyre size: 265/75R17
Fuel Type: 95 RON
Name Of Workshop: LG Automotive
Date Dynoed: 12/02/2011
wnt 17
37
beenleigh
vn 5ltr execitive
286 hydrolic cam
harrop manifould
1000 cfm efi hard wear throtel body
shaved heads took 50 thou off has bout 9.5 comp now
and valve springs to suit cam
bigger injectors
msd coil
8mm leads
haltec computer there would be more but cant think
that is the last run befor it was kick off because of rear main leaking a lil
when i fix it will be back on for final tune
GM GEN3
GM GEN3
37
S.A
legs ATM
GM GEN3 / BRADLEY / VX SS
HP (XXX.Xhp), kW (242.1RWKWS)
Engine Type and Capacity:5.7L
Power Adders: OTR TUNE
Diff Ratio: 3.9.1
Wheel/Tyre size:STOCK VX SS 17 INCH
Fuel Type: PREMIUM
Name Of Workshop: WILLALL RACING
Date Dynoed: 20/12/2010
