Dyno Sheets
flyen
bye bye
forums.justcommodores.com.au
flyen/ mike/ vn clubsport
kW (152.9rwkw)
Engine Type and Capacity: VS HSV 185 V8 5L
Power Adders: ss cai, zorst
Trans Type (M6, A4, etc): auto
Diff Ratio: 3.45
Wheel/Tyre size: 18
Fuel Type: bp 98
Name Of Workshop: towler
Date Dynoed: july 07
flyen / mike / VS SS
kW (136rwk)
Engine Type and Capacity: v8 5L
Power Adders: cai
Diff Ratio: 3.08
Wheel/Tyre size: 15
Fuel Type: bp 98
Date Dynoed: nov 2007
angelo.vs
Autobot
40
Honda Accord Euro Luxury
angelo.vs / Angelo / VX Berlina
KW: 230
Engine Type and Capacity: 5.7 LS1
Power Adders: VX HSV headers, twin 2.5 cat-back, MCAI + 2 hole mod, GTS MAFless pipe, MAFless tune by Dale at CHE
Trans Type (M6, A4, etc): A4
Diff Ratio: 3.08
Wheel/Tyre size: 18's
Fuel Type: Caltex 98 at time of dyno tune
Name Of Workshop: Castle Hill Exhausts (CHE)
Date Dynoed: 11/08/07
vtgtsblownstroker
N.S.W
VTGTS
Vtgts
VT GTS 5.7L
HP 516.7RWHP , KW 385.9RWKW
Engine Type and Capacity: 355 stroker
Power Adders: blocked bored 30thou,O-ringed,350 stroker crank,30thou oversized ross pistons,10;1 compression,crome moly rings,scat rods,ported cast heads,1mm oversized ferrea stainless steel valves,CC'd chambers,K-line valve guides,yella terra roller rockers,crower valve springs,titanium retainers,custom crane camshaft,V7Y vortech supercharger,8psi boost,romac harmonic balancer,oversize crank pully,pacemaker extractors,two into one exhaust,custom 600x500x80 intercooler,custom inlet plenium,105mm throttle body,Haltech E11v2 engine management system,holly red pumping into a 2ltr surge tank then twin bosch 044's up to the injectors,turbosmart fuel pressure regulator,1000cc rochester injectors,MSD digital-6 plus ignition,Tremec T56 6 speed gearbox with a heavy duty brass button clutch.
Diff Ratio:stock
Wheel/Tyre size: HSV 18X8 inch rims,Falken Ziex 245x40x18 tyres
Fuel Type:
Name Of Workshop: Summernats 2008
Date Dynoed: 04/01/2008 516.7RWHP/385.9RWKW
RVN 355
WEST SUBS
91 VN SS 355
rvn 355 dyno results march 2008
RVN 355 / Brad / 1991 VN SS
HP (XXX.Xhp), kW 172.6 rwkw
Power Adders: 355 come crank,9.9 comp,Crane 284 cam,30tho,3" pod,Haltech E6GMX,500hp heads,I beam Rods 5.7",MSD fuel pump,JP Oil Pump,Yella Terra Roller Rockers,Speed Pro Flat Top Forged Pistons,K-line valve guides,Stainless Valves,Rollmaster Double Row Timing Chain,2500 stall,Pacemakers Competetion Headers with hpc coating,3" Magnaflow Mufflers,High Flow Cat,8.8mm leads.
Trans Type (M6, A4, etc): stage II TH 700
Diff Ratio:stock
Wheel/Tyre size: 245 45 R 19 RJR Torque on Maxxis MA Z1
Fuel Type: 98 Shell V Power
Name Of Workshop: BDT (Blackwood Dyno Tune)
Date Dynoed: March 2008
nicko
Carbon Positive - DO IT!!
sa
75 cruiser ute
Nicko / Nick (duh) / VT Series 2 exec
HP (166rwhp), kW (123.9rwkW) (If you only know one, ill work it out for you)
Engine Type and Capacity: 3.8L ecotec
Power Adders: none when dynoed stock as
Trans Type (M6, A4, etc): M5
Diff Ratio: 3.08:1
Wheel/Tyre size: 15s
Fuel Type: BP98
Name Of Workshop: morpowa
Date Dynoed: 1 month
EvoVIIIJDM
Got Evo?
www.justcommodores.com.au
Evo VIII JDM
LS1Chub / Luke/ VX Clubby
(241rwkw)
Engine Type and Capacity:LS1 5.7
Power Adders: OTR and Tune
Diff Ratio: Stock
Wheel/Tyre size:R18
Fuel Type: 98RON
Name Of Workshop: Willall Racing/ LS1 Turbo
Date Dynoed: Couple weeks ago
__________________
tanka5.7
vq
tanka5.7/damo/vq statesman
HP (XXX.Xhp), kW (145.4kW)
Engine Type and Capacity: 304 v8
Power Adders: reversed ls1 maf pipe with k&n pod and 2 1/2 inch exhaust with high flow cat
Trans Type : full manual t700
Diff Ratio:3.45
Wheel/Tyre size: 205/65-15 at the time
Fuel Type: 98 ron
Name Of Workshop: castle hill exhaust
Date Dynoed: 5/3/08
Cursed CX8
Banned
Walking distance to FG meets
VY Adventra
pulling off the pod might give you better power reading. A CAI and K&N will stop the engine pulling hot air from the engine bay, and will still allow great flow
Cursed CX8
Banned
VY Adventra
good point on the bonnet being up. but what about road driving, its going to heat up under there.
