Pcm flash and sensor for ls3?all u need is the flex sensor (if u dont have one) and enable it and get tuner to fill in the flex areas and ur good to go on one tune
yep should be just fit sensor and wire in to ecu then enable flex tables and populate, not sure on the ratings but i think the factory flex did have bigger injectors and maby pump, see what your WOT injectors duty cycle is now and add 34% to it and see if ur about 80% total or less ur safe, also good to make sure ur injectors like ethanol as some dontPcm flash and sensor for ls3?
Any idea what stock fuel setup is rated for. Ie are the injectors and pump high flow enough for e85?
