Easy and free fix for vz v6 engine miss (faulty ECU)
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by 60HOM, Aug 10, 2013.
  1. 60HOM
    60HOM New Member
    goldcoast
    VZ V6
    Hi everyone, this is my first post after following the site for awhile because my vz v6 developed a miss. Long story short it end up being a short in
    No.6 INJ circuit, it was going to cost me $900+ for the ecu and $200+ to configure it :/
    Being a mechanic myself I looked into it and found all I had to do was use one of the other INJ circuits to earth No.6 INJ, after splicing into INJ No.5
    the miss disappeared :) with trouble free driving sence. So if anyone else out there has the same problem and wants to save $1000+ then replay on this post and ill detail how the carry the fix out, only takes about 15mins.
    Gus69, shoieb, Matty mgwm and 3 others like this.
  2. 99notout
    99notout Active Member
    VZ Equip Wagon
    Yes please, if you have any diagrams or pictures that would be fantastic. Thanks for the offer! :beer chug:
    Berlina&Jag guy likes this.
  3. greenacc
    greenacc Searching for the billion
    VE Berlina
    How did you diagnose it ?
  4. 60HOM
    60HOM New Member
    goldcoast
    VZ V6
    To diagnose is easy.
    First disconnect each coil pack one at a time while the engine is running to find the missing cyl, replace that coil pack with another cyl's coil pack to see if the miss moves to that new cyl or stays in the same cyl.
    If the miss moves then your coil pack is faulty, if it stays then and the spark plugs are good then its your inj which means your ecu has dropped out that inj due to a possible short from that coil pack.
    Now to fix it without spending $1000+ on a ecu and tune
    1. locate inj harness connection at the rear of intake manifold left side
    2.if you look at the rear of the plug on the main harness side it should look like this.
    brown/white pink/black brown/blue green red
    yellow/black blue/black green/black
    Cyl No.s
    5 3 1 + +
    6 4 2
    3. Now lets say No.6 is missing, grab your test light and test No.6 wire but earth it on either the green or red power wires, the light should just stay on, you'll see after testing the other cyls that it should flash dimly.
    3.now just cut No.6 (yellow/black) wire on the main harness side the splice it into No.5 wire (brown/white). its always good to splice it to the cyl earlier in the firing order eg No.2 to No.1 or No.4 to No.3. Then start engine
    myxr8 and shoieb like this.
  5. 99notout
    VZ Equip Wagon
    Wow thanks for the reply and suggestion. Just a question, would that mean that the dead injector that you just spliced into and earlier injector wireing would get its impulse and inject the fuel into the cylinder too early??
  6. 60HOM
    60HOM New Member
    goldcoast
    VZ V6
    Technically yes but no, your talking about a difference of about .01 sec at 4000rpm, it wouldnt really matter what injector the spliced into but I would just use the earlier injector because why not if your doing it.
  7. diysv6
    diysv6 Member
    SEQ
    VF S1 SV6 STORM A6: VZ S1 SV6 A5
    Hi 60HOM,
    I really liked the way you got around the failed injector switching from the ECU on #6 cylinder. Does the extra switching current on INJ#5 transistor switch exceed the transistor's specifications, or is there a safe design margin in the ECU? Would you stay with this rewire in the long term, or look around for a good, reasonably priced second hand unit?
  8. maxcol
    maxcol New Member
    cairns
    Crewman
    With your firing order the ++ are the drivers seat ?
    CoachYT likes this.
  9. vzladyowner
    vzladyowner New Member
    beerwah
    vz
    Hi my vz has a miss and my mate who works for racq would really appreciate your knowledge on how to fix it for me
  10. alloytec sludge
    alloytec sludge Member
    vic
    vz
    engine miss
    i did this today to stop a constant miss and it worked yah
  11. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    Sticky maybe or in the how-to's?
  12. alloytec sludge
    vic
    vz
    just here in this post
  13. roamin
    roamin New Member
    Hello and thank you for the handy info.
    Currently i am having a injector issue on a vz that makes the car run terrible and also comes up on the dash with a check powertrain issue. I have an obd scanner which told me it was an injector circuit. When i meter across the wiring they all measure 8.5v but when i meter the brown/blue wire i get 1.2v so i take it thats my suspect wire.
    Does anyone have any check power train issues after cutting and splicing? Also did anyone else have a check powertrain issue leading them to this?
  14. DarrylBarba
    DarrylBarba New Member
    Darwin N.T.
    VZ Executive
    Gday mate...
    I am curious about how to suss out the misfiring issue.... I have a 2004-2005 model VZ wagon Exec... and a month ago it started to shake really badly when idling and up to the 80km mark... The mechanic who checked it says the ECU had **** itself and was the reason for the misfiring which had nothing to do with the Injectors. So after replacing the ECU it still had the shakes and even after replacing the spark plugs (which hadn't been changed since 2011) it still now has the shakes. I feel i have been "taken for a ride" as i have no bloody idea and trust in the mechanics knowledge... Originally the dash showed a warning sign saying Check Drive Train .. Cost me too much already i know this thread is from a while ago so i wonder if all is still running good in regards.
    Darryl
  15. Shadowstorm
    Shadowstorm New Member
    Qld
    Vz crewman
    Hi I am keen to do this , but what do you mean by splice? My faulty cylinder is the front right if standing in front of the engine ( is that 2? ) and if it is do I just pull out wire going to cylinder 1 cut the plastic back and do the same to the faulty wire , wrap them around each other than jam it back up where cylinder wire 1 was? And will this work fine ? Thanks in advance and sorry if I sound a little nieve but I can't afford anything as I live in Australia
  16. Shadowstorm
    Qld
    Vz crewman
    hi I'm keen a short vid or pic would be ace
  17. alloytec sludge
    vic
    vz
    try these splicers just make sure they splice through to the copper wire underneath
  18. alloytec sludge
    vic
    vz
    dam not sure how to send pics
  19. alloytec sludge
    vic
    vz
    try this see if it works
      File size:
      113.3 KB
      3,835
  20. pete_pumpkin
    pete_pumpkin New Member
    VP 93 BT1
    I just tried it after swapping coils around etc, confirming 6 is playing up. Spliced 6 into 5 aswell. Funny thing is 5 years ago I replaced coil 5. Anyhow it didn't make a difference. My elm327 doesn't seem to work either so maybe i'll buy a new one of them first before I go any further. I did buy a non contact vltage sensor but that didn't pick up anything on those cables.
    edit:
    Changed out injector 6, still same problem. Ordered a compatible obd2 scanner, should have it next few days.
