eaton112 on stock 5ltr
sporty custom
Banned
51
terang
vx
putting eaton112 on stock 5 ltr machined banana manifold down aluminium plate on top supercharger mounted so that sides all good. do i need to run a 2bar map sensor i was going to run blue tops standard throttle body about 8psi boost any imput be good cheers for now
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
Yep you will need one
eaton v8
my little sleeper
gladstone qld
Skip the 8 psi go 12 to15 at least get a methanol kit it will gain heaps withat as well and it acts as a bit of intercooling as well
eaton v8
my little sleeper
gladstone qld
Put a set of mls gaskets on just to be safe as well
sporty custom
Banned
51
terang
vx
ok thanks for response i see you have been there done that yeah just sorting my way thru it all at moment once i get it up and running will look at bigger throttle body 2 60mm set up like you had plus 36lb injectors most of set up is home made so slow going but not gunna rush it any other advise would be appreciated aswell cheers.
eaton v8
my little sleeper
gladstone qld
Pm matt_vp I think he should have a 8psi tune that foam did for me. But I had 42 pounders.
sporty custom
Banned
51
terang
vx
oh ok cheers for that least if i get a basic tune its somewhere to start cheers again
AirStrike
35
91' VN SS
Blue tops in a boosted setup.......good luck!
eaton v8
my little sleeper
gladstone qld
It could be done as long as he had a meth kit for it but I don't have a tune for that. I only used the meth after I put the heltec in it. I have a feeling the blue tops is all mws use in there basic set up but I could be wrong it is only 8 psi or it might have been the white super 6 injectors.
AirStrike
35
91' VN SS
L67's I would say fair enough, but a boosted V8 with 24lb injectors I would call questionable.
