ebay alloy radiators
42
Wollongong
VH SL Wagon
I'm up for a new radiator in my VH V8
I have 2 stock ones both need work dues to being 30 years old so i'm getting a new one
I can get a full alloy chinese radiator for $200 or a australian copper core for $300
are the chinese alloy ones ok?
I also have a 16in thermo fan to use and get rid of my old clutch fan, will this be ok too? or should I run dual shrouded thermos
I can get the dual shrouded thermos to suit the VH for about $190 delivered from ebay
my brother runs a small alloy radiator with 16in thermo in his v8 rx4 and it never gets hot but have heard holdens don't like thermo fans for some reason
corhijasna
Portland Victoria
have you tried repco etc,they are usually pretty good,you could always see what the other customers have said about the quality of the radiators through the feedback of the seller
thermo fans are mainly for when the cars are stopping and starting all the time,when rolling the airflow usually above walking pace is pretty good at keeping things under control
stockies
Bannana
S/E Suburbs
G6E Turbo
Full alloy Chinese radiators are ok to use in a Commodore. Just make sure its got mounting points for a fan as most don't.
Also - Ground the radiator with a thick cable to prevent stray voltage - Commodores have this in abundance. Otherwise your radiator won't last 6 months.
stockies
Bannana
S/E Suburbs
G6E Turbo
personally id only ever use copper radiators. less potential headaches. they work, they have always worked and they will always work.
Until the plastic tanks split...
42
Wollongong
VH SL Wagon
no plastic on a my VH radiator, but i have had many ford ones split, last radiator i bought was for me AU XR8 and cost me $90 for a new natrad from ebay and worked perfect
touch wood the VX radiator is still going fine after 210,000km
NPreston
Victoria Point
VC
I have a Chinese Fenix radiator I bought off ebay in my VC track car, no issues whatsoever.
Do as Stockies said and earth it.
42
Wollongong
VH SL Wagon
there seems to be 2 types on ebay, one with a 45 deg filler tube and one with a 90 deg filler tube, which one is the better type/brand
ari666
250,000 hits
