Ebcm issue
ckyjack
nsw
vs commodore
hey guys i have 2010 ve 3.0 and have a issue with the stability control turning its self on and off while driving so i hooked up the vident i400 and with engine off key on the dash flashes abs and stability fault and i get a no com to the abs module but with key on engine on the no com disappears and the flashing errors on dash disappears any suggestions
lout
60
Langwarrin Victoria
check battery voltage
most likely due for a new battery
REDRUM-6L
39
'10 VE SS 6 Spd redline
Hey mate
I got the same problem, did u end up finding out what the issue was
Fu Manchu
WA.
Hey mate
Check battery voltage
Load test battery.
Check charge circuit.
When there is insufficient voltage while the car is running, that circuit is one of the first to be deactivated by the ECM to put more voltage into other areas. The worse the voltage supply gets, the more systems are deactivated and more fault codes generated.
