gregando
- Nov 23, 2010
- 23
- 0
- 0
- Age
- 45
- Location
- newcastle
- VX HSV XU6
everything will work fine with that ecu its exactly the same part as the VX S/C comes with stock just different memcal.it could just be going real rich up top it costs lots of power or your fuel pump may be struggling to keep up does it show knock on the scantool when it does it
No the mechanic says shows nothing wrong but the timing is getting retarded. I should have it put on a dyno i spose but i don't like the way they charge up here just to do a quick run. Its got me beat ive changed all the vac/boost hoses, spent **** loads on new sensors and a bosch 044 fuel pump that i still have to fit, checked and checked diagnostics had it up the local mechanic that many times now that when he sees me coming he grabs his scan tool lol. One thing i forgot to mention was i put the larger injectors in after it started playing up because it recorded a lean running conditions under load so i put em in and it did nothing to fix the problem and thats where i started chasing my tail.
