VSSECO
Underdog rebuild
- Aug 29, 2007
- 439
- 3
- 0
- Location
- VIC
- VS - 6 pots, 5 cogs
So I'm going to be partially stripping down the old V6 for a manifold swap and some head work... While I'm there I've been considering disabling the balance shaft.
If I throw a double row timing chain on it will I be able to safely disable the shaft without too many problems?
To the guys that have done this... How rough does the engine run without it??? and would you reconmend doing it??? Where did you get your double row chains?
I'm running standard cam, just looking to reduce some rotating mass in the old girl...
