ecotec guru's needed please
danieljo
Darwin
VE SS 08
hi guys I have since done the inlet manifold gasket as they were stuffed, I cleaned everything before it went back on the car I serviced the injectors and stuffed one but replaced it with a new one, now it blows white smoke, I don't think its oil cause it doesn't smell like burnt oil and hasn't got a blue tinge to it, any ideas would be great please
EYY
VS Statesman
If it's blowing white smoke, either your head gasket(s) is/are damaged or the inlet manifold gasket's leaking. If it's white it'll be steam. How much is it blowing?
dirty hands
ipswich qld
magna
was it blowing as much white smoke before you did the inlet manifold gasket
_R_J_K_
Zenki S14
Daresay it's coolant. Does it blow liquid out the exhaust if you give it a decent rev?
Should pull the plugs and see if there's anything on them
danieljo
Darwin
VE SS 08
Never blown white smoke before, and its heaps of smoke like someone it toking away on a joint, I don't understand how it could be leaking brand new inlet gaskets and the head gasket should be fine as it wasn't doing it before, but could be wrong, any where else it could be leaking from maybe I haven't done it up tight enough? I used 14nm as I found on the internet?, and I didn't really notice any liquid.
danieljo
Darwin
VE SS 08
am I suppose to put any thread seal on the inlet bolts at all, coz it looked like it had some on it, I wasn't sure tho thought it could of just been gunk one them?
greenacc
Searching for the billion
VE Berlina
How did you tighten them to 14Nm? What size torque wrench?
dirty hands
ipswich qld
magna
my repair manual says 12 -18 nm on inlet manifold bolt
on this job ..14 may not have been enough
there are a few posts in this forum when something has gone wrong after a lim gasket replacement
your are not the first to have a problem like that
easy to do a forum search on their experiences
if you cant sort it you may have to do the work again
take a good look around the inlet manifold ... see what has failed .. and refit another one gasket set
try a search
There is a link in this forum somewhere for an free downloadable VT/VX repair manual
some small annoying detail probably
flat surfaces not smooth
one speck of old gasket stuck somewhere
the failure of a less cost no name brand gasket set
sealant needed
old bolt ...stretch .. umm you think .torque ?
greenacc
VE Berlina
14 is very light for a 1/2inch torque wrench. You'd be better off with a 3/8.
Ij you're desperate you could try tightening the bolts up a bit tighter but sounds like you need to do it all again with new gaskets, some good sealant and perfectly clean surfaces.
My guess is a gasket has moved as you put it back together and you'll find it when you take it apart.
