ecotec in 1991 vg ute
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pollock12, Apr 26, 2011.
  1. pollock12
    pollock12 New Member
    macarthur vic
    1991 vg ute
    hi all,i am atm doin up a vg ute as a p plater car, its original a buick with a 8 bolt flywheel and a t5. I have cut out the firewall and am puttin in a vs firewall with the dash, I am wondering if i put the vs ecotec motor with the wiring off the motor and the ecu will this work as the rest of my wirng for my dash is gonna be a vr loom. Any help will be much thanks
  2. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    im kinda confused... not sure you had to cut out the fire wall. if your putting in a vs engine loom and computer with a vs dash, wouldnt it be easier to just put the vs dash loom in too? i did a series 1 vn calais swap to a vn lexcen (series 2 vp engine) i just swapped everything over including the body loom so theres no conflicts anywhere... the only thing i dont know about is if your body loom will plug in 100% or not... if you got a vg 91 ute where does the vr loom come in?....
  3. pollock12
    macarthur vic
    1991 vg ute
    i met that i have cut my firewall out due to the vs dash having different mounting points to say the vn dash and the de-frosters are a different setup. The vr dash loom came into cause i was original gonna put the buick back in the car and i found a vr with a buick in at the wreckers, and the vs-vr dash are the same, so i grabbed the loom outta of it. But now i am interested in a ecotec, just curious if i can put a vs engine harness and computer in, and i will change the dash loom to vs one if its easy done.
  4. hi_ryder
  5. pollock12
    macarthur vic
    1991 vg ute
  6. yZoH
    S/E Subs, Melb
    (0.o')
    Then buy a VS
    My VN had a VY Ecotec motor + VS Caprice Dash...
    The dash bolts in, Fibreglass your own underdash vents. All mounting holes are the same.
    Soo..
    Why do you think nothing bolts up and/or works...
  7. pollock12
    macarthur vic
    1991 vg ute
    i dont wanna buy a vs, as i got this cheap and the body is straight as, and i have spent hours on doin a respray and smoothin the engine bay. I thought it was different cause the vs dash has got 5 bolts to hold the dash the vn one has 3? correct me of i am wrong.
  8. Clint_G
    Clint_G Member
    05 VZ SS
    that sounds about right but it will still hold up with the 3. i had a vs dash in my vn and with the 3 bolts it sat in there fine
  9. pollock12
    macarthur vic
    1991 vg ute
    doesnt really mattter now already cut it out. And got a firewall out of a vs from comcar.
  10. pollock12
    macarthur vic
    1991 vg ute
    i like the way u have done the engine with all the buick pieces extra well done. but i would rather just put the whole lot over motor harness and computer.
  11. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    www.l67torque.com • Login
    Have a look at the link I posted above. There is a lot of information there on putting supercharged ecotec's in VN-VR's so you might be able to apply some of that knowledge to your project. Ive seen your car on SC it looks like a wicked project. I was looking at VG utes a while back but they were mostly overpriced and trashed unfortunately
  12. pollock12
    macarthur vic
    1991 vg ute
    thanks mate, i was lucky with this one, where i use to live it was just 5 houses down and was out the front of his house for months and asked him bout it and yea $1250 later had it. was a fair bargain with a manual and one little tiny dint in the tub, which popped out
