ECOTEC in VR
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SSbeast, Sep 12, 2006.
  1. SSbeast
    SSbeast New Member
    Is it possiable to transplant a VS V6 engine in to a VR? And is it a direct fit or do u have to mod the mounts? Thanks.
  2. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    y would you bother?? just buy a VS. if your going 2 transplant then atleast go a v8. but 2 answer ur q id say itd fit with out much hassel at all.
  3. SlyVR
    SlyVR Fo'sizzle....
    VR Wags
    it would be possible, ive seen a vn with a vs engine, it does mean that u have to exchange the firewall, tho it might be cheaper unless you get all ur infomation correct and have the tools to help. tho i have heard it is possible.
    slyvr
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I'd imagine you'd also have to fit a VS wiring system as the ECU and trans are different...and then there's the BCM etc. But I'd agree with the others - why bother. (unless the price is right)
  5. immortality
    Sth Auck, NZ
    Have read in other threads that it's possible to run the ecotec motor with the earlier ECU which maybe better for performance cause the earlier setup used an MAP sensor and not the MAF sensor like the ecotec. bit of stuffing around however as you would need to adapt the earlier wiring loom to the ecotec and apparently you will need to fit the sensors from the early ECU/engine to the ecotec as well. anthings possible i guess for a price:whistling
  6. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    VY SS S2 11.284@125mph
    You will need to use the engine mounts off the ecotec & it will bolt straight in. The electrics will need modifications as will the exhaust.
  7. whisky
    whisky Guest
    just keep your vr ecu and ditch the maf, all you will need to change over is the knock sensor from the vr block and replace one of the knock sensors on the vs block with it. Next up you will need to use one oxygen sensor instead of 2 so you might need to get an exhaust shop to tap a hole in for you after the cat.
    Good luck with it all. Also if you stick with the VR ECU it will make getting it tuned later on easier. Plenty of people have been ditching the MAF and using a VR ECU to gain power.
  8. SlyVR
    SlyVR Fo'sizzle....
    VR Wags
    i thought the MAF sensor was imporant? can you take it out to gain power?...
  9. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    The VR engine doesnt use a maf. They use a map & mat sensor to calculate fuel.
  10. Greedz_VR-S
    Greedz_VR-S Guest
    hey...heres an idea....sell the VR and buy a fken VS?? No.....thats too logical...
  11. sv9946
    sv9946 New Member
    VE ss ute hopefully, or ss-v
    true greedz_vr-s but i mean like why anyhow there is f^ck all power difference from a vr to a vs, unless you go for a vs supercharged but like he said save a lot of money and head aches and buy a vs (stronger auto and 2 knock sensors and 2 oxy sensors and maf sensor) all adds up to better more fuel efficent engine
  12. dmitch
    dmitch DonkeySS
    Perth W.A
    VS SS S2
    i agree cheaper to sell the vr and buy a vs
