Ecotec lacks power on petrol, but good on LPG
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jeepster, Jan 1, 2013.
  1. jeepster
    jeepster Member
    WA
    VSII Ute
    Car runs just fine on LPG. I use petrol a little. Mostly when crusing home, the tacho would only be about 1500 RPM.
    Then petrol seems okay under low load.
    Yesterday, I went up a steep hill, and could only do 40 km/h - it was struggling. I swtiched back to LPG,
    and speed shot up to 70 km/h. It was not misfiring on petrol. The exhaust does not smell strange either.
    So I would suspect that fuel pump is knackered and can't deliver volume, or a sensor not used by LPG
    is bad, such as MAF.
    Any other possibilities?
  2. aussieakito
    Melbourne, Victoria
    Injectors, fuel pump.
    Must have something to do with either of them?
    Try replacing the fuel filter
  3. jeepster
    jeepster Member
    WA
    VSII Ute
    I replaced the fuel filter, but it kept getting worse. I took it to a fuel injector service place, and they said injectors are okay, ya pump is kaput.
    That puzzled me, as I tought these in-tank fuel pumps died suddenly, rather than gradually choking.
    So I got a replacement fuel pump, and removed the old one. Well, the filter bag looked like a dog turd - it was completed coated in clay.
    Also the sender float, pipes and other bits had a beige coating all over them. I put on a cotton glove and stuck my fingers into the tank.
    Everything is coated with this cack.
    The tank was previously replaced by a dealer workshop because return hose was busted. Since new tanks are no more made, they had to
    get one from a wrecker. Well it must have been in some dusty ourback town, and the ######## mechanics didn't clean it out before
    fitting it.
    :hmmm:
  4. yoshi87
    yoshi87 New Member
    south australia
    vs commodore
    was urcar caughin for a little bit then died or just not performing well?
  5. Jonah 101
    Jonah 101 Undefined
    Rotorua
    R32 Skyline
    Sounds like you have it sorted, but Check you intake pipes too. If you have had a backfire and it ripped the intake pipe or blown a vacuum hose off you will have trouble.
