Ecotec lower inlet manifold
grey_hawk
S.A
VR V6 Ute, VS V6 snotbox
Hi all, just doing the lower intake manifold gasket on a VS.
My question is; is it possible to install the intake manifold on it's own (ie without injectors and plenum.)
Or does it have to be installed as a 'unit'?
Cheers,Mark.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Hi Mark,
You have to pre-install the injectors to underside of the upper plenum and then lower that complete assembly onto the top of the lower intake manifold (valley) and bolt it down. So yes the valley should be installed on it's own prior to the rest being done. Ensure to apply a bit of Vasoline onto and around the O rings of the injectors prior to slipping them back into their openings in the valley. Not too much but enough to create an easy slipping action into place.
two-bit
old enough to mang better
VS S series II
can be installed on its own and injectors and upper plenum can be popped on after just make sure you have the correct gaskets etc no point doing it all twice, if you have a workshop manual (can be found online) it tells you how to do it all and whats needs to be installed in what order
grey_hawk
S.A
Thanks guys, I have a workshop manual but it wasn't really clear how it was put back together,I thought it should go but wasn't sure if the injectors would line up.I tried putting it back together in separate parts and it all worked out but the heater tube was hard to get in what a carp idea that is...
