Utel67
- Jul 15, 2019
- 341
- 146
- 43
- Location
- Tasmania
- Vs s3 ute
You are going to need a 2 bar map tune
Maf input D1 moved to B10 at pcm
Cut Maf wires
Black goes to A on map
Brown with white trace to B on map
Grey to C on map
Pink is not used
You will need to tap the intake manifold for a MAT sensor (manifold air temp).
Extend your IAT wiring (intake air temp) and plug into the MAT sensor.
Cut Maf wires
Grey to C on map
Pink is not used
