ecotec memcal
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by andyman, Apr 16, 2007.
  1. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    ok i read somewhere that some vs were released with some ecu/memcals with tunes that made the engines miss when cold, has anybody heard or expiranced this, and is there a possibility i have this ecu/memcal,
    the reason being is like i have posted before my car has a miss when you hit the accelerator only when the engine is cold, ive had my car on the diagnostics machine at tafe and there was no faults detected after running the tests
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    misses when cold aye?
    Check the gap on your spark plugs?
    Are the plugs and leeds any good?
    Air/Fuel filter any good?
  3. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    it shouldn't miss when cold at least mine doesn't, even tho it still have rough idle problem.
  4. andyman
    Orange, NSW
    everything is new and tripple checked, thats why im clutching at straws,
    a experienced mechanic where i work at said hes had a few vs's that are pretty fussy with what plugs you put in them and have the same symptoms as what ive got, so ill go and get some genuine delcos or ngks that holden have.
    i was thinking it may be tune related as i just had a bit of a good trip in my car and it now dosnt appear to be as bad but still there
  5. andyman
    Orange, NSW
    yeah thanks attaboy, i know,
    it has stumped the lads at work aswell , after the trip i had in it the idle is alot better than before as i had the battery disconnected a few times after doing work
  6. ephect
    ephect Donating Member
    VS Acclaim V6
    yea there was a definition that fixed the hesitation from idle.. cant remember which, but yes there was a factory one..
    have you a bored out throttle body? my hesitates from idle on a quick burst..
    ok, i remember reading that on some throttle bodys, the butterfly had an X marked on it.. some actually had a lil hole drilled where the X normally sits.. this may be a fix to ur solution, drill a 2mm hole where the X is..
    attached is a pic of the X on mine
  7. jc58nc
    jc58nc Guest
    Best if you remove your ECU and drop out the memcal, take the blue cover off it by lifting one end and tell us what the 4 letter code is on the alloy label.
    It will be something like BSTK or BWPJ. This way we can tell you if there is any gains by swapping Memcals.
    For your infomation f you go to Dr Bob's site http://www.memcals.com/ under info he has a listing of all the Vs Memcals that were used.
  8. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    could be a el cheapo ebay memcal
  9. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The VL's were bad for this, advancing the cam timing one tooth usually fixed it. Couldn't do that on a VS though. Try a bottle of injector cleaner.
  10. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    BTXP replaced BSTK1451 to fix cold hesitation and pinging in the VS 3.8L.
  11. jc58nc
    jc58nc Guest
    That's correct but Vs v6 had 4 wire heated or 2 wire O2 sensors, so it's best to find out what he has first.
  12. 88GreenVN
    Surprise, Arizona
    OK should have said that the VS did have an update Memcal at some point.....:thumbsup:
  13. andyman
    Orange, NSW
    ok my memcal is: bstk 1451 serial number appears to be: 72444 95291
    drbobs website says:
    BSTK1451 $51 3.8L Auto 16210672 Replaced by BTXP for Cold Hesitation and Pinging
    so i suppose i have the problem memcal,
    next step, should holden replace this for nothing? was it a recall or anything?
  14. 88GreenVN
    Surprise, Arizona
    I'd try Holdens out on that. They replaced my coils on my VN after 80,000kms when it was about 5 years old (Ithink thats about right)
  15. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    The worst they can say is no.
  16. andyman
    Orange, NSW
    how much do you reckon holden would charge, about 200 maybe, if its a ridiculous price, ill give our wreckers ago, and drbob
