As mentioned earlier on here The oil filter stuck out too far and would hit on the boat stringers when fitted.
Looked at several different solutions to solving this problem including remotely mounting the filter elsewhere and running pipes to it, and also cutting away part of the stringer to give it some clearance.
This is what I decided to do to fix the problem
First of all I needed a block of aluminium which I didn't have any the correct size.
So I fired up my home built Kiln and poured some molten Alloy into an old coffee tin roughly the right dimensions.
Did a couple of these so I have a backup if I stuffed the first one.
Next I machined the coffee tin off using the lathe to expose the alloy inside.
Then I machined the rounded surfaces needed and then put it in the mill to drill out and tap the oil galleries. Also while I was playing with the mill I decided some cooling fins and engraving could look cool.
This is the filter mount Before
And After
Unfortunately My skills at doing letters free hand in the mill need a tad more practice but the end result is quiet acceptable and it should do what it needs too.
One day I may have to upgrade the mill to full CNC LOL
Cheers Andy
