Hey, as the title says, anyone know how hard or whats needed to do this?!?!? It can be done relatively cheap.... Patch loom.... And retune of VN ECU. Anything else?!?!?! Cheers MaT EDIT: Read this http://forums.justcommodores.com.au/showthread.php?t=17519&page=24 You will see why I need new motor.......
squeakotec into vn should bolt right in physically, with some small modifications to the air intake pipe... but i'm sure you could use a vs one throttle cable might be a bit longer on the squeakotech too.. and radiator hoses will be different too maybe? run the VN computer and have it tuned to squeakotec specs.. this will save you stuffing around with the newer ECU and BCM and other thigns that it will have an effect on.... you might be able to get away with using the VN loom with some small modifications so plugs can reach sensors? Other than that, it should be pretty straight foreward? any parts that you need could probably be found on a VS? Luke.
Nah going ecotec....... And within a year it'll get an m90blower setup... But just for now i need a MOTOR IN HER!!!!!!!!!!!!!!!!!!!!
lol, can i ask how does that happen??, i was worried about rubber shooting out from under neath and it was only the harmonic balancer..., wont there be issues with the gearbox's ?
