ecotec oil capacity?
pillzor
VS executive
i understand its 4.5 litres, is this correct? and if doing an oil change after 5000ks should i bother doing the oil filter aswell?
Brett_jjj
Tamworth NSW
vs commodore
4.3 litres with filter,I would be replacing the oil filter every time the oil is changed,they are cheap to buy anyway.I always add around 4 litres then use the dipstick to finish off topping it up.Start the engine,let it idle for a minute or two then let it sit for 5 minutes and then re-check the oil level.
pillzor
VS executive
so where exactly do i drain the oil from?
Wombles
Cars cost too much.
Underneath the engine, where the engine sump is there is a sump plug. Get a spanner/socket+ratchet and undo that. Bye bye oil.
pillzor
VS executive
thought so, does it need too be warmed up or cold is better?
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
Oil drains better when it is warm, ie thinner. I always change my filter, on the VY it costs about $10.
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
Hang on!!! The oil capacity is 5.3 litres for an ecotec, says so in book and I always have to ensure that i have a bottle with some left over from the last change as a five litre bottle is not enough. Unless the earlier ecotecs had a smaller sump? But can someone confirm that last bit please.
wortus
I'm pretty sure the oil capacity on a VS ecotech is a fair bit less than a VY. The VY's I think have a larger sump capacity to enable an increase in the service interval from 10,000km to 15,000km. That said I'm not so sure about leaving oil in for that long. I always use a new filter. I find genuine parts are usually cheaper if you find the right Holden dealer.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
The book for the VS says 4.3 litres.
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
