Ecotec to VN/VP
yZoH
//There Ain't No Rest For The Wicked...
S/E Subs, Melb
www.lolwut.com
(0.o')
Conversion:
What You’ll need to fit to the ECOTEC Motor from a VN/VP Motor:
  • VN/VP 5ltr Kick down Cable
  • VN/VP MAT Sensor
  • VN/VP Coolant Temp Sensor
  • VN/VP IAC
  • VN/VP TPS
  • VN/VP Knock Sensors
  • VN/VP Oil Pressure Sensor
  • VN/VP Lower Radiator Hose
Other things needed:
  • VS Brake Vacuum Hose
  • VS Upper Radiator Hose
  • VS P/Steering Reservoir
  • VS Accelerator Cable
  • VS Intake Pipe
  • To fit the MAT sensor to the ECOTEC Plenum, You will need a `14x1.5 Tap` Acquirable from most metal work places. I used that and tapped it to the Driver side center of the intake manifold
  • The coolant temp sensor on the ECOTEC is on the front of the engine just under the thermostat. The ECOTEC uses a 3/8 npt thread where the BUICK is an 8mm metric thread. To overcome this in my car I have drilled & tapped a 3/8 to 1/8 reducing bush & used as an adaptor.
  • The fuel lines on the ECOTEC are designed to clip on the steel fuel lines, however the earlier model cars don’t have the right connections & there is a bit of messing around to get them fitted. While the main pressure line will take a 5/16 fuel line when it is disconnected from the rail end, the return line is smaller. You will need to leave the nylon inner on the barb on this one & push the 5/16 return line over it.
Aswell you may need to get a tune, It runs quite well on the VN's memcal ATFY but on the VP memcal, Don't remember the letters it should run better because it does not have as advanced timing because the ECOTEC runs more timing anyway.
From those few steps, Everything apart from that is pretty straight forward.
You can get a Custom Y-Piece made up to go from the Manifolds/Extractors to Your Cat back exhaust for $100-$150.
If I have forgotten anything that anyone need's to know, Please let me know...
EDIT:
WIll be Including any pictures I took while doing the conversion ASAP
MaT
P.S- Now if anyone comments that mine does not run right I'd like you to prove it. People have asked how to run it like this, I'm just stating it.
Pic 1 = Tapping of the Inlet Manifold
Pic 2 = Before with VN V6
Pic 3 = After Finished Conversion
JD
Donating Member
34
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
how about that gas incident you posted up under general? ( jks )
but on a serious note this should be a sticky!
1vngal
34
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
Or in the how to section :p
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
I'd suggest leave it here for a few days so the people needing can view it, then it be moved and/or stickied. That way I can keep adding to it.
MaT
Matt_vp
Donating Member
39
Gladstone Qld
vy lumina v6 A4
good write up mate, thanks i've been thinking about doing this conversion for a while.
Matt
Shortstuff
Random
2016 Golf GTI PP
You used all the original sensors off the Buick V6, so does that mean there was very little mucking about with the wiring? Just extending of some parts of the original loom?
Also have you got any pics of the fuel lines where the VN stuff meets the Ecotec stuff?
yZoH
S/E Subs, Melb
www.lolwut.com
(0.o')
Correct, All the original sensors must be used because all the VS-VY ECOTEC sensors output different voltages/signals meaning the VN/VP's DELCO 808 ECU will not log it, Causing it to run incorrectly.
MaT
Shortstuff
Random
2016 Golf GTI PP
Ok. Thanks! Looks like the engine in mine has had it so I might have a look at doing this.
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
did you have to change your exhauts manifolds to suit the ecotec?
