ECU Error Code P0521
IlukaV8
46
Campbelltown NSW
VE SS Commodore Series 2 AEM
P0521 PowerTrain
Engine Oil Pressure Sensor/Switch Range/Performance
Im getting this randomly
So I have change the Oil Pressure sensor twice at the back of the engine next to the firewall.
Now I doubt its this.
Oil Changes are on time and oil is clean.
Its a 2010 VE SS Commodore
Thank you
krusing
Melbourne, Bayside
I have it as the same error code on my records.
P0521 Engine Oil Pressure (EOP) - Sensor Performance ECM DTC P0521, P0522, or P0523,
Since you have replaced the EOP, Maybe check the connector plug, and trace to back to the ECM, and check its continuity, and resistance from point to point.
Circuit/System Testing
1. Ignition OFF, disconnect the harness connector at the engine oil pressure (EOP) sensor.
2. Ignition OFF, test for less than 1 ohm between the low reference circuit terminal 1 and
ground.
3. Ignition ON, test for 4.8-5.2 volts between the 5-volt reference circuit terminal 2 and ground.
4. Verify the scan tool Engine Oil Pressure Sensor parameter is less than 0.2 volt.
5. Install a 3A fused jumper wire between the signal circuit terminal 3 and the 5-volt reference
circuit terminal 2. Verify the scan tool Engine Oil Pressure Sensor parameter is greater than
4.8 volts.
6. If all circuits test normal, test or replace the EOP sensor.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
• Circuit Testing
• Connector Repairs
• Testing for Intermittent Conditions and Poor Connections
• Wiring Repairs
If greater than the specified range, test the circuit for an open/high resistance. If the
circuit tests normal, replace the ECM.
If less than the specified range, test the 5-volt reference circuit for a short to ground or an
open/high resistance. If the circuit tests normal, replace the ECM.
If greater than the specified range, test the 5-volt reference circuit for a short to voltage.
If greater than the specified range, test the signal circuit terminal 3 for a short to voltage.
If less than the specified range, test the signal circuit for a short to ground or an
• Engine Oil Pressure Sensor and/or Switch Replacement for 4.8L, 5.3L, 6.0L, 6.2L, or 7.0L
engines
• Engine Oil Pressure Sensor and/or Switch Replacement for 3.6L engine
• Control Module References for ECM replacement, setup and programming
hope this helps.
IlukaV8
46
Campbelltown NSW
Thankyou for that. Never thought of the plug itself too. Will start from there and then cable. Could be a loose connector inside the plug!
Mister Magu
59
Vy one tonner
I just had a code P0521 come up on my10 Caprice with AFM. Deleted code only to come back a few days later. Car has done 150k ,auto has flairing issues . Google AFM issues with LS motors. Come to think of it , had an annoying tappet noise that come and went . Lifter changed might be the order of the day before we chew out camshaft lobes ! $$$$$$$ Drain oil in clean tub and split oil filter open for metal filings
krusing
Melbourne, Bayside
How did you go ?,
Did you find the fault ?
krusing
Melbourne, Bayside
geekcohen
30
Warragul, VIC
Holden VE Omega 2007
krusing
Melbourne, Bayside
The other thing that came to mind to check, is the gauze filter under the OPS as that could be partially block.
