Ecu options
Discussion in 'Tuning' started by w1r3d, Sep 11, 2015.
  1. w1r3d
    w1r3d New Member
    vs ute
    Hey guys what options are there for aftermarket ecu on a 195i 304 with a intercooler and a v1 blower? Do wolf still make them?
  2. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Why waste money on an after market ecu when the factory is more than up to the task, you just need to find a tuner who can tune a Delco PCM.
  3. w1r3d
    w1r3d New Member
    vs ute
    I have heard of some software that allowed a tuner to download, wipe then tune a factory ecu. I ask as it seems that after getting warm the car goes into a limp mode where the revs climb then drop. I believe i still have a stock pcm, would removing the battery cause the setting to be wiped??
  4. immortality
    Sth Auck, NZ
    Removing the battery will wipe the PCM memory and you will loose the learnt fuel trims but the basic tune from the factory will always be there.
    If you want to learn more about tuning a delco have a look over here PCMHacking
  5. w1r3d
    w1r3d New Member
    vs ute
    Would a custom memcal store trims even after the battery is disconnected?
  6. immortality
    Sth Auck, NZ
    No
  7. w1r3d
    w1r3d New Member
    vs ute
    That's why I was asking what ecu options there is.
    As i have a kill switch in my ute which i use when i am not driving it, just for security sake.
  8. immortality
    Sth Auck, NZ
    Fuel trims aren't important if the tune is right. All the fuel trims are once the engine is up to operating temp the ECU uses the O2 sensors to make small adjustments which change everyday because of changing weather conditions, temp, humidity, pressure etc.
  9. w1r3d
    w1r3d New Member
    vs ute
    I think it needs a good tune because when the engine has warmed up and left at idle it will rises the rpm then drops, rise then drop etc.. Would this be limp mode?
    The motor is not factory it been upgraded to a 195i 304 with a V1 blower with a 5 speed T5. What do i ask? Because i want to be able to use my kill switch but not lose tune and be in a limp mode..
    I have heard some good news about the Capa Performance. When looking locally(Alice Springs) there is not much options, it's that bad that the only dyno in town is owned by the police!!
  10. immortality
    Sth Auck, NZ
    Something is not quiet right but I wouldn't think it would be going into limp home mode.
    Has the tune been changed over to suit a manual transmission?
  11. w1r3d
    w1r3d New Member
    vs ute
    I am not sure. I was told that the ecu was not excess able via the aldl plug under the steering wheel. Sounds like i need to trace back the wires. Where would i find specs for the wiring?
    Do you think it's in limp home mode once it gets warm by rising and dropping revs?
    I just want to know what might be wrong and what to say to my mechanic.
  12. immortality
    Sth Auck, NZ
    If it's still wired as per the factory then yes the OBD plug can be used.
    Is the engine check light on? Is the thermofan on?
    The rolling idle may be related to the manual conversion if the tune hasn't been adjusted to suit.
  13. w1r3d
    w1r3d New Member
    vs ute
    None of the warning lights are on. The thermo fans have been replaced with dual fans with Davies Craig thermal switch.
    I have just purchased a aldl to USB connector and a vs workshop manual. As i need to sort out all the bugs that make driving it stressful.
    .i know the engine is from a 195i VT 304, but i don't know if the original gearbox for the ute or the VT engine.
    What info can you get from the VIN plate?
  14. SimonL67
    SimonL67 New Member
    MELBOURNE
    2004 Vy Calais L67
    Wolf has new one a V550 just had one fitted to my VY supercharged V6
  15. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    I recall reading somewhere that an ls1 ecu can be adapted to suit, don't ask me how as I have no idea but could be an option?
  16. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    Best to go over to delcohacking forum and ask about there. You will find heaps of very knowledgeable guys who if you ask nicely will help you out for a small fee. I had a HSV tune with a few tweaks burnt onto a new memcal for the mrs' super 6. Worked well.
