ECU reset???
cdawg
NSW
VY Spac Supercharged L67
I have a VT Acclaim ecotec and wont to know how to reset the ECU.. and would it affect anything or will it basically give it a refresh?? cheers
BOGANV8
I gotta V8 whoot whoot
41
Armidale
VX 02 SS LS1
disconnect the battery for up to 5-10 min then reconnect as far as i know
1VTACCLAIM3.6
Guest
air bag warning light
The air bag warning light is showing on my dash board and has been doing so since i removed the drivers seat , do u think if i reset the ecu it might reset the warning light as i have put the seat back in and connected all the cables again but the light has not gone out??
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
No it won't reset. You'll have to get it reset by Holden or someone with a Tech2
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
if you cycled the ignition with the seat disconnected the SDM will have logged a code, you need to get it cleared with a tech2.
Rob
1VTACCLAIM3.6
Guest
thanks
i will get it done at holden next service
Cheers:whistling
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
1VTACCLAIM3.6 said:
thanks
Cheers:whistling
I would get it fixed ASAP. Your airbag might not deploy in an accident as it has registered a fault.....
