ECU
David Rieck
54
Tirroan
VU ute and VY Calais
Hey guys , Is the ECU in 2002 VU v6 ute the same as 2004 VY v6 . want to swap it out of my vy to see if it fixes an issue .
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
Security won't let the car start if you swap ecus.what issue are you trying to fix
David Rieck
54
Tirroan
have a rough idle/miss. it all points to #1 cylinder. swapped out all the sensors bar oxygen and crank . checked for vac leaks , even a mechanic said it was a faulty #1 injector . So full set of injectors went in . Still no joy . cleaned the maf and swapped it out as well . cleaned the throttle body .
David Rieck
54
Tirroan
swapped out coils , leads and plugs, swapped dfi modal, compression test done it was ok
middlesbrokid
Australia
vy calais supercharged v6
Hi I am having major start problems from time to time I have notice there's a little (x) in the climate control window. Everything I have read to date is telling me its the ecu. I have purchase another one and wanting to fit it (but) it seems that I will need a scantool or get the vats removed, will this allow me to change them over and have the car run without a scantool, can anyone shed any light on this. I was told by the so called experts that changing the bcm would fix this (ha ha ). Problem still there and getting worse I have noticed when running right, the gearbox position is displayed in the window on the dash briefly and further research is pointing to the ECU
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
I have a vt with climate control & used the hvac climate control on a vy. Different boxes, but both do the same thing.
I was getting x in the climate control window. Took it to the the auto electricians. He said something about an actuator being broken.
Took it home & checked the wiring plugs were in tight. One wasn't, so after pushing it properly in, no more x in the window.
Check all the plugs for BCM. Maybe you have loose plugs?
Its something you can try yourself, without costing anything except some time.
ant797
bunbury
vy s
Your throwing parts at it costing you a fortune take it to a different mechanic
